benarmeriii Friend
benarmeriii
- July 2007
April 23, 2009 at 12:00 am #140518The “read more” text has underscores when the cursor is not over it ( please see attached screenshot). Once you hover over it, it shows correctly, i.e. as an underlined text.
I don’t know where to go to correct it.
Also, as you can see….the “read more” text is actually very hard to read, as it’s almost the same colour as the background….where can I change the colour of that text too please?
I’m just not sure which CSS, and/or which line I need to edit.TIA
jsliao Friendjsliao
- April 2008
- 236 times in 210 posts
April 23, 2009 at 1:50 am #302266pls post a live URL so we could look more into this problem as it does not seem to exist when I tried using the template
nguyenhuu quang Friendnguyenhuu quang
- 328 times in 288 posts
April 23, 2009 at 1:56 am #302269check Your languge,
or, download lastestversion and update your site. (or upload languges directory)
thanksTAnne Mills FriendTAnne Mills
- 14 times in 1 posts
April 24, 2009 at 5:32 am #302409You can edit the opacity of the text to make it more readable without the mouse hover as oulined in this thread – http://www.joomlart.com/forums/topic/text-description-in-slideshow-not-viewable/
Can you post your URL so we can see the problem with the underscores?
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 4 voices, and was last updated by TAnne Mills 15 years, 8 months ago.
"Read More" problem
