  • mikeli Friend
    #150052
    i have problem in ja quartz quick start, i can’t get read more show in articls..
    Dear mikeli!
    Pls try to check again
    1) have you put the readmore tag inside the content of article ?
    2) You check the configuration of the menu having the blog layout: the Read more… Link parameter is “Show” or not ?
    3) In the global setting of the content component: you can find it in the toolbar of the content manager, it’s the “Parameters” button. In there you check the Read more… Link parameter is “Show” or not ?
    That all
    GOod luck
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 8 months ago.
