  • Phill Moderator
    #143829
    Not really a JA problem this one.
    I’ve recently discovered a problem with the readmore button but it only seems to happen in IE8, on FF it is ok.
    If I use TinyMCE the editor makes the readmore link <hr id=system-readmore> obviously missing the “” marks.
    If I use No Editor I get <hr id=”system-readmore” /> which is correct.
    Does anyone know a fix for this? I’ve tried it on a number of IE8 installs and it is the same on all.
    If I use FF the readmore button gives <p><hr id=”system-readmore”><br mce_bogus=”1″></p> which works but wtf is the mce_bogus bit?
    This is all really annoying having to manually edit the readmore code for every new article someone submits for which I have multiple users doing so.
    mihirc Friend
    #315904
    I personally havnt encountered the problem before. But I think you can try adding a www while opening the administrator.
    I am not sure it will work, but this is a random guess.
    Many problems do arise without the www so you can just try it out.
    Regards,
    Mihir Chhatre.
This topic contains 2 replies, has 2 voices, and was last updated by  mihirc 15 years, 4 months ago.
