  • max_santiago Friend
    #206226
    Hallo JA all!
    Google reCaptcha registered and all ok,
    I put public e secret codes,
    also set ON in Global Config and Plugin > ON.
    But nothing in Contact… only a text ‘captcha’ with a little yellow asterisk.
    Any suggests?!
    Thanks!
    M.
    Hi Max,
    Did you try to check the reCaptcha with default Joomla template?
    max_santiago Friend
    #570367
    Saguaros, after dns subsostitution to new domain in Google ‘domain’ was…old website name.
    Pardon… and thanks! 🙂
    Max
    You meant that it’s solved ?
This topic contains 5 replies, has 2 voices, and was last updated by  Saguaros 9 years, 7 months ago.
