  • bleu Friend
    #182056
    I’ve got a couple of problems,
    1st: when I want to add a new field in the application form I need to rebuilt the database but it doesn’t work and I get this message: Error updating the table..
    2nd: After a job seeker save the modification to is resume in the front-end, for some reason, the page loads in the wrong template (it’s not the default template) and the modification are not saved and he have to edit it again.
    3rd: When a job seeker try to upload a resume in a job application the lightbox appears and the white box where he have to choose is resume, is outside the page, only the bottom is showed and he can’t scroll to get to the top of the box
    thanks
    HeR0 Friend
    #472369
    Hi Bleu,
    => Please update full Privileges for db account
    2nd, 3rd => If you resolve 1st issue, 2nd and 3rd can be done. If not, PM me admin account, ftp info, i’ll have a look and help you out.
    Regards,
This topic contains 2 replies, has 2 voices, and was last updated by  HeR0 12 years ago.
