  • christofferl Friend
    #1038133
    I have a problem with the function of the visitors being redirected in a wrong way when trying to login and use the wrong user or pwd.
    This can easiest be seen an experienced by
    1. Go to this link
    2. Try to login with any data or just hit the login button
    3. … you are now directed to the 1st welcome page which is not how it should be. What should happen is that you stay on the same page and get the message that the login and/or pwd is wrong.
    Let me know if you need furhter info.
    Pankaj Sharma Moderator
    #1038254
    Kindly create User menu if you want to show the wrong login will redirect to that page.
    Create a login menu on your site, so it will not use the system URL.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 5 months ago.
