imported_lorenzoadorni Friend
- May 2015
August 10, 2017 at 6:48 am #1054905Hello,
I need to reduce the white space between the end of the slideshow and the start of the first module in content-must-top position.
As you can see in the attached image there is too white space.
How can I do that?Thank’s.
August 11, 2017 at 1:36 am #1055728Hi
Kindly follow the same suggestion i shared with you for the module height,
it work for both the issue.Regards
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 1 reply, has 2 voices, and was last updated by Pankaj Sharma 7 years, 4 months ago.
