Viewing 5 posts - 16 through 20 (of 20 total)
  • Syrhc Friend
    #909111
    Ninja Lead Moderator
    #909301
    There maybe issue with the layout override of template, you can try using FTP account and rename templates/ja_magz_ii/html/com_tags/tag/default_items.php file to default_items_bk.php to make it work
    I’ve also reported this issue to development team, you can track its status here
    plassen Friend
    #910151
    Hi – I have the same problem – is there a temporary fix?
    plassen Friend
    #910153
    @ninja Lead – the problem persists after renaming the overrides. This is a fairly important fix to make – it’s a news template. This is vital for the site I’m setting up right now. When will this be resolved??
    #910340
    @plassen: I must check this bug directly on your site, please give me the URL of your site, admin login backend of your site via your reply and set as private reply.
This topic contains 19 replies, has 4 voices, and was last updated by  Ninja Lead 8 years, 9 months ago.
