brusamolino Friend
brusamolino
- January 2009
- 10 times in 2 posts
January 5, 2017 at 4:23 pm #999964Hi
Can you tell me how can i remove the text animation (on mousever) inside "Introducing" module in homepage?thanks Luca
pavit Moderatorpavit
January 5, 2017 at 6:49 pm #1000018Hello
Edit this file ja_mono/acm/features-intro/css/style.css and comment line from 86 to 92 in this way
/*.acm-features.style-1 .features-item:hover .feature-image { -webkit-animation: image_animation 0.6s; -moz-animation: image_animation 0.6s; -o-animation: image_animation 0.6s; animation: image_animation 0.6s; } .acm-features.style-1 .features-item:hover .feature-content { -webkit-animation: content_animation 0.6s; -moz-animation: content_animation 0.6s; -o-animation: content_animation 0.6s; animation: content_animation 0.6s; }*/
brusamolino Friendbrusamolino
- January 2009
January 6, 2017 at 12:16 pm #1000266Hi
i have commented line inside style.css (in templates/ja_mono/acm/features-intro/css and templates/ja_mono/acm/features-intro/css/themes/blue) from 86 to 92 but i have the same problem
you can see it on http://gurrieri.dot360.it/index.php/projectscan you help me?
January 6, 2017 at 8:01 pm #1000397Hello
Looking at your page i noted it is still active, look at image below
Ypu can also remove it and enable css optimization from backend
- January 2009
January 9, 2017 at 10:46 am #1000875Hi
i’ve found the problem
it takes the css under templates/ja_mono/local/acm/features-intro/css and not under templates/ja_mono/acm/features-intro/cssnow is ok
thanks Luca
October 11, 2017 at 5:13 pm #1067333Hi
could You check the path to the css
because I want to remove this efect , I comment templates/ja_mono/acm/features-intro/css and templates/ja_mono/acm/features-intro/css/themes/blue) from 86 to 92 – it doesn`t help/And in the local folder I don`t have style.css
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 3 voices, and was last updated by pleban78 7 years, 2 months ago.
