  • ventasman Friend
    #1056359
    Hi. Is there a module class suffix for removing padding to the sidebar positions?
    Thank you!
    Pankaj Sharma Moderator
    #1056397
    No it’s not the module suffix the padding applied on the sidebar is coming from the parent container.
    Here is the code used for this
    .t3-sidebar {
        background-color: #f6f6f6;
        margin-top: 28px;
        padding-top: 28px;
        padding-bottom: 28px;
        padding-left: 40px;
        padding-right: 40px;
    You can add this code in the custom.css file and reduce the values as per needs.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 4 months ago.
