  • bloggs_x Friend
    #120344
    I would like to remove the virtuemart pathway, the picture in the product description, the manufacturer, the vendor information, and the last updated
    I have tried editing the flypage to no avail! Please help me!
    Michael Casha Friend
    #220435
    bloggs_x Friend
    #220449
    Anyone? 🙁
    instantinlaw Friend
    #220743
    Hi I may not be of much help here but if you replace the “no product image” with a clear gif, and don’t publish an image with your product, you will have what you are looking for on that point.
    I also tried to remove the manufacturer info link and had no luck, but I didn’t try too hard. Instead I added other information to the page that comes up when you click the link.
    As far as the vendor info goes, I was able to get rid of that, but it was so long ago I forget how I did it. I am sure that the settings are in the configuration screen though. I will take a look and post my findings. I have made a tutorial on adding products to VM, so if I can figure out what I did I will make another one for you.
    I believe there is another thread on the pathway question. Try doing a search.
    I’ll be in touch
    instantinlaw Friend
    #220744
    This just in….
    Two of the settings can be found here Admin>Configuration>Site>Display
    One is for the default product image, the other is for the pathway settings.
    See attached image for the places you are looking to change.
    Still looking for the vendor stuff.
    1. screen
    instantinlaw Friend
    #220745
    After looking around the VM admin area I seem to remember that all I did was to delete all the vendors that were loaded by default. Go to Vendor>list vendor and delete all the vendors in the list. I probably deleted all the vendor category listings too.
    You can delete any manufacturers too, but I don’t think you can delete the default one.
    I hope this helps.
    instantinlaw Friend
    whouse Friend
    #227632
    To remove the pathway, the checkbox in the admin config didn’t work for me. There was a post on the VM forum that did the trick for me. Edit the flypage.php file you are using and remove the {navigation_pathway} from the code (you only have to remove the first line that contains the {navigation_pathway})
    Original file looks like this:
    <br/>
    <table border="0" style="width: 100%;">
    <tbody>
    <tr>
    <td rowspan="4" valign="top" style="text-align:center;"><br/>{product_image}<br/><br/>{more_images}</td>
    <td rowspan="1" colspan="2">
    <h1>{product_name} {edit_link}</h1>
    </td>
    </tr>
    <tr>
    <td rowspan="1" colspan="2">{manufacturer_link}<br /></td>
    </tr>
    <tr>
    <td width="33%" valign="top" align="left">{product_price}<br /></td>
    <td valign="top">{product_packaging}<br /></td>
    </tr>
    <tr style="font-style: italic;">
    <td rowspan="1" colspan="2"><hr />{product_description}<br/><span style="font-style: italic;">{file_list}</span></td>
    </tr>
    <tr>
    <td>{product_availability}<br /></td>
    <td colspan="2"><br />{addtocart}</td>
    </tr>
    <tr>
    <td colspan="3">{product_type}</td>
    </tr>
    <tr>
    <td colspan="3"><hr />{product_reviews}</td>
    </tr>
    <tr>
    <td colspan="3">{product_reviewform}<br /></td>
    </tr>
    <tr>
    <td colspan="3">{related_products}<br /></td>
    </tr>
    <tr>
    <td colspan="3"><div style="text-align: center;">{vendor_link}<br /></div><br /></td>
    </tr>
    </tbody>
    </table>
    {navigation_childlist}<br style="clear:both"/>
    After removing the line this is what it looks like:
    <br/>
    <tbody>
    <tr>
    </td>
    </tr>
    <tr>
    </tr>
    <tr>
    </tr>
    </tr>
    <tr>
    </tr>
    <tr>
    </tr>
    <tr>
    </tr>
    <tr>
    </tr>
    <tr>
    </tr>
    <tr>
    </tr>
    </tbody>
    </table>
    TomC Moderator
    #227635
    <em>@instantinlaw 18243 wrote:</em><blockquote>found this over at VM
    http://virtuemart.net/index.php?option=com_smf&Itemid=71&topic=19514.0</blockquote>
    I’m surprised you didn’t find this thread over at VM . . . http://virtuemart.net/index.php?option=com_smf&Itemid=71&topic=30834.0
    TOM
This topic contains 9 replies, has 5 voices, and was last updated by  TomC 17 years, 4 months ago.
