  • lauraperin Friend
    #142198
    I would like to remove the sitename in the Home Page, just below “You are here” section.
    I am using firebug, and I found the instruction to remove it using firebug.
    The problem is that I do not know how to find the corresponding html file to remove it.
    I found css files in firebug on the right, but I can’t find html file.
    Please could you help?
    Thanks a lot
    Laura
    hanifahmed Friend
    #308941
    Have you tried the following in the backend:
    Menus -> Main Menu -> Home -> System (Parameters) (on the right) -> Show Title: Off
    lauraperin Friend
    #308946
    Great!!! 😀 Thanks a lot!
    Laura
This topic contains 3 replies, has 2 voices, and was last updated by  lauraperin 15 years, 6 months ago.
