  • jmccann Friend
    #131943
    Any ide why all formatting is removed when SEO friendly url is swir0tched on with JA Teline?
    Removing Alias doesnt fix problem.
    #264411
    Can you please send via PM an admin account of your website so that I could look into the issue.
    jmccann Friend
    #265796
    Have you manged to find out why SEF URLLS arent working?
    questbg Friend
    #265802
    When you activate SEF URL’s you need to rename htaccess.txt file in your root Joomla folder to .htaccess
    Then log into Admin, to go Global Configuration and:
    Use Apache mod_rewrite set to ‘enable’.
    That should do it.
    Good luck
    Chris
This topic contains 4 replies, has 3 voices, and was last updated by  questbg 16 years, 4 months ago.
