  • crazyleggs Friend
    #187483
    I’m using the tablet theme on my site, and would like to use a mouse over event on the toggle button (for sidebar menu) and search button rather than point and click. How can this be accomplished?
    Wall Crasher Developer
    #492767
    Hi crazyleggs,
    This task requires a little bit customization to the script.
    You should consider hire a developer at http://www.joomlancers.com/ to help you out.
    The basic idea is replacing ‘click’ ‘by ‘mouseenter’ at line 445 on file /templates/ja_wall/js/script.js
    But it need to check and verify on other screen size to make sure it supports responsive feature
    Sorry for be not of much help here.
This topic contains 2 replies, has 2 voices, and was last updated by  Wall Crasher 11 years, 6 months ago.
