March 10, 2011 at 9:47 pm #161306
I use Teline III v2 template and would like to replace its footer module with Teline IV footer module (which is much more complete).
Thanks for your help 😉Thanh Nguyen Viet FriendThanh Nguyen Viet
- 258 times in 217 posts
March 14, 2011 at 3:14 am #381162Hello mate,
– copy the file “blocks/footer.php” from template “Teline IV” to template “Teline III V2”
– clone stylesheet of footer section from template “Teline IV” to template “Teline III V2” ( you can find it on “templates/your_template/css/template.css” file.Best regards,
ThanhNV1 user says Thank You to Thanh Nguyen Viet for this useful post
April 3, 2011 at 10:24 am #384648Can you help me, I’d like a whole: sitemap and footer. How to replace the IV to III v2?
Can you tell me step by step how to do it?
Sherlock FriendSherlock
- 2478 times in 2162 posts
April 6, 2011 at 4:34 am #385063<em>@wredny 231972 wrote:</em><blockquote>Can you help me, I’d like a whole: sitemap and footer. How to replace the IV to III v2?
Can you tell me step by step how to do it?</blockquote>
hi wredny,
You should install a III V2,check the custom HTML modules for that position, copy the HTML code and move it to the teline IV as new custom module.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 4 voices, and was last updated by Sherlock 13 years, 7 months ago.
Replace Teline III v2 footer module with Teline IV footer module
