  • turtlesoup Friend
    #208057
    It’s super unfortunate but I have to install Ark Editor for my current clients. (I think it’s going to happen to all my Joomla clients :laugh: )
    One problem, Ark Editor’s fixed navbar. It destroys my client’s website using Teline V. I have to fix this BS and to do that I have to request for z-index mapping of Teline V.
    Can one of your devs do a Sass map instead of individual global z-index variables?
    Cheers.
    Our templates are built with Bootstrap framework and with LESS – not Sass
    turtlesoup Friend
    #575996
    oh my bad … LESS map then? any idea how to deal with my problem with ark editor’s frontend navbar on Teline V?
    Thanks.
    I’m not sure which problem are you facing with that 3rd party editor. As you mentioned in the first post, you already fix it, if you fix via css, you can post the solution here then I will guide how to deal with it via LESS file.
This topic contains 6 replies, has 2 voices, and was last updated by  Saguaros 9 years, 4 months ago.
