  • L John Friend
    #723792
    I have added a responsive module that shows a video in portrait mode; when the phone is flipped horizontal it work. When the phone is flipped back to portrait it keeps the horizontal size and extend beyond the size of the div. Other modules and video players works fine.
    Thx
    Hi John,
    Which module are you using?
    You can try to check the responsive feature of this module with default Joomla template first and see how it goes.
    Hi John,
    L John Friend
    #723894
    <em>@Saguaros 501861 wrote:</em><blockquote>Hi John,
    You can try to check the responsive feature of this module with default Joomla template first and see how it goes.</blockquote>
    I am using SJ Video Box; I did a quick test on their site and the same problem exist. Since i am now using the module on a Template that is mobile compliant, is there a way to get the module to process mobile transition vi the template’s media queries? Basically to have Wall handle all media queries?
    Thx
    L John Friend
    #754339
    Thx
    I’m afraid that in a responsive template, you will need to have extension supporting responsive too. Kindly check with provider of this extension whether they support this feature or not.
    L John Friend
    #724012
    Thx Saguaros,
    The module is responsive and works but resizes back from landscape oversized. Loads in portrait fine; loads in landscape fine; load in portrait flip to landscape fine; flip back to portrait and its oversized.
    The module is unsupported but provides the function that I am looking for.
    L John Friend
    #754404
    Thx Saguaros,
    You can raise request that responsive feature to its provider, that extension must support responsive layout before using in a responsive template.
This topic contains 11 replies, has 2 voices, and was last updated by  Saguaros 9 years, 1 month ago.
