  • SiteWeavers Friend
    #205233
    I seem to have an issue with the Article-Category module layout when displayed in tablet mode. I have the module set to display 6 articles (link provided in post details).
    If you resize your browser window while on that page you will see it displays 3 columns for desktops, then 1 column for tables which is all misaligned, then 1 column for mobiles which looks good again. The tablet view is the one with problems, ideally the tablet view should have 2 columns.
    From what I can make out it is something to do with the bootstrap layout classes in the module, ‘col-sm-12’ in particular, I changed this to col-sm-6 in firebug and it allowed two columns for tablets but the links below were still misaligned.
    Can you please give some guidance on how I can fix this?
    Many Thanks 🙂
    chavan Friend
    #565573
    once you change it to col-sm-6, then Add this code to /templates/ja_sugite/css/custom.css
    @media screen and (min-width: 768px) and (max-width: 992px) {
    .category-module .ja-animate .mod-articles-readmore{
    display: block !important;
    float: none !important;
    text-align:center !important;
    margin-left: 0px !important;
    SiteWeavers Friend
    #565609
    Thanks for your reply, where do I change it to col-sm-6?
    I’ve looked in the module via joomla admin and also in the module directory under mod_article_category but can’t see any files that display the html I need to change.
    Many Thanks
    chavan Friend
    #565618
    Your admin details are not working, please check and provide us the correct details
    SiteWeavers Friend
    #565619
    PM’d you details
    chavan Friend
    #565861
    I have made the change for you and the change is made in this file : /html/mod_articles_category/three-columns.php
This topic contains 6 replies, has 2 voices, and was last updated by  chavan 9 years, 8 months ago.
