  • reverbatim Friend
    #190148
    I am actually coding a website (http://www.reverbatim.com) using the Ja Mero template but I am facing page setup problems.
    I created some module positions and try to move others one and now it is a real mess : nothing aligns correctly in any screen resolution.
    I do not say it is your work to make my website but I am asking for help.
    I do not understand why some module remains fixed in any resolutions and why some others do not. In fact there are problem with the logo (the mobile version never appears), the main menu (not correctly located on smartphone screens resolutions), the top bar menu icon (does not passe above on smartphone), the bottom bar menu icon which does not align correctly and the slideshow : it remains fixed so everything scrolls under it.
    If you can please look at my website and just tell what is going wrong I would appreciate it.
    By the way I can not the the “JAT3 clean cache” button, do you have any idea why ?
    Ninja Lead Moderator
    #504102
    I have fixed this css style problem on your site with this solution:
    Open templates/ja_mero/css/themes/ja_mero-reverbatim/template.css file
    From
    .navbar-collapse-fixed-top,
    .navbar-collapse-fixed-bottom {
    border-top: none;
    position: fixed;
    left: 0;
    top: 0;
    width: 100%;
    z-index: 1000;
    Change to
    border-top: none;
    position: absolute;
    left: 0;
    top: 0;
    width: 100%;
    z-index: 1000;
    Please check responsive on your site again
    reverbatim Friend
    #567424
    Hello and thank you for your reply,
    The problem has been fixed. Thank you.
This topic contains 3 replies, has 2 voices, and was last updated by  reverbatim 9 years, 7 months ago.
