Pankaj Sharma Moderator
January 28, 2016 at 3:35 am #870300Hi
Kindly share your working site url here , so i can check this issue directly on your site and suggest you some changes to solve this issue .Radonja Djurisic FriendRadonja Djurisic
- 72 times in 15 posts
January 28, 2016 at 1:15 pm #870576This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
January 28, 2016 at 2:51 pm #870686Hi
The title is showing in the center and the content is also showing fine > http://prntscr.com/9vy7j4
Did u solved it ?Radonja Djurisic FriendRadonja Djurisic
January 28, 2016 at 4:03 pm #870731try to lower the resolution a bit u will see the problem
January 29, 2016 at 7:18 am #871239Hi Tolja
i checked it in lower resolution too and its seems fine at my end : http://prntscr.com/9w9l9h
Kindly provide the device name in which you are facing this problemRadonja Djurisic FriendRadonja Djurisic
January 30, 2016 at 6:08 pm #872448Hay Pankaj,
i forget to test other browser compatibility
i notice that this happen only on Firefox browseris there any fix for this ?
February 1, 2016 at 2:29 am #873027Hi
Add this code in custom.css file#section-101 .acm-features .features-item > div { display: block!important; }
Save file clean cache and check.
February 4, 2016 at 3:45 am #875947Thanks Pankaj,
This topic contains 8 replies, has 2 voices, and was last updated by Radonja Djurisic 8 years, 9 months ago.
The topic ‘responsive problem’ is closed to new replies.
