Viewing 5 posts - 16 through 20 (of 20 total)
  • Phill Moderator
    #413415
    In plugins/system/jat3/jat3/base-themes/default-rtl/css you will find the line below in template.css line 427
    background-image: url(../images/icon-badge.png);
    You will need to edit that path to point to the image in question.
    sal2010 Friend
    #413486
    It look that all images in the: default-rtl/images are broken!
    It is very frustrating to me!
    In the localhost it is works OK but on the live server ” failed to load the given url”
    When I edit it I received this info:
    Forbidden
    You don’t have permission to access /plugins/system/jat3/base-themes/default-rtl/images/icon-badge.png on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    May this problem of permission!
    Any ideas how to fix it
    n6rej Friend
    #413513
    contact your webhost and ask them to “reset” the permisoins on all folders/files to 755/644 Akeeba may be able to do this for you.
    sal2010 Friend
    #413562
    thank you ALL
    Now is OK
    it look that is server access permessions
    n6rej Friend
    #413591
    your very welcome
This topic contains 20 replies, has 5 voices, and was last updated by  n6rej 13 years, 3 months ago.
