  • richard4 Friend
    #119683
    Seems to be a regular request for a fix for the problem of the right hand column moving down. My experience so far is that the Events calendar is the problem. There is already a fix for the earlier version which appear already on this forum, and a different fix for the new/latest version which I managed to achieve today.
    To fix older version go to Modules folder and open mod_extcalendar_minical.php and find these numbers – 135px and 139px and change them to 100%.
    In the new version this has moved and is now found in mod_events_cal.css, and here the number is 140px. It appears twice and in each case should be changed to 100%.
    Hope this helps someone with the problem. Rember, if you are using Firefox you may not know you have a problem. As always, it is important to check you site in IE.
    arnoldkoning Friend
    #221990
    I have the same problem and cannot find these modules, i also tried shutting off some modules and that didnt work either. Its a serious problem though. Anyone else have a solution?
    miconr Friend
    #224540
    But don’t forget to change the mod_events_monthyear to 100% as well…just to keep things tidy!:D
This topic contains 3 replies, has 3 voices, and was last updated by  miconr 17 years, 5 months ago.
