  • Rob Hawthorn Friend
    #144664
    Hi, I’ve created a banner in the “right” position (right column position). It appears but it’s background container doesn’t stretch over the whole area.
    The following attachment illustrates the problem:
    Any help’s very much appreciated
    1. bannerproblem
    Anonymous Moderator
    #318995
    Hi rob_hawthorn
    I have checked your website but could not find this issue.
    Did you fix it?
    Rob Hawthorn Friend
    #319005
    <em>@JA Developer 146788 wrote:</em><blockquote>Hi rob_hawthorn
    Did you fix it?</blockquote>
    Hi, no I think the client (who is also working on text for this may have disabled it). The module position is “right” and it’s called “Banner square” and it’s appearing like the previous attached image
    hariorama Friend
    #319006
    nice pic: D
    Rob Hawthorn Friend
    #319277
    Cao, the problem’s still appearing, should I post a ticket or can you help?
    Regards,
    Rob
    Anonymous Moderator
    #319352
    Hi rob_hawthorn
    Please open templates/ja_lead/css/template.css file, at about line 1651, find following code:
    div.advs {
    clear:both;
    display:block;
    float:left;
    width:100%;
    and change to:
    div.advs {
    clear:both;
    display:block;
    width:100%;
    Rob Hawthorn Friend
    #319382
    Thanks Cao, very much appreciated
This topic contains 7 replies, has 3 voices, and was last updated by  Rob Hawthorn 15 years, 1 month ago.
