  • davidrabinov Friend
    #148960
    More problems,
    I have set the Who’s Online Module to display everywhere. It’s in Spanish – Visitantes
    View it here, set in the Right Module Position – http://www.panamasportsmagazine.com/ scroll a bit down to see it.
    View it also here in a category, again in the Right Module Position – http://www.panamasportsmagazine.com/index.php?option=com_content&view=category&layout=blog&id=13&Itemid=20
    However – It’s gone here in the Article! – http://www.panamasportsmagazine.com/index.php?option=com_content&view=article&id=322:chava-y-miss-chief-ganan-la-regata-de-cayucos-copa-tribunal-electoral-2010&catid=13:remo&Itemid=20 just a blank Column.
    What am I doing wrong here, I need something in that column.
    Anonymous Moderator
    #333959
    Hi you
    I could not find the Who’s Online Module in your website
    i think you disabled it
    Please feel free to contact us if you are in need of further assistance.
    davidrabinov Friend
    #334153
    <em>@JA Developer 166609 wrote:</em><blockquote>Hi you
    Please feel free to contact us if you are in need of further assistance.</blockquote>
    It is not disabled, it’s there. Read my first post and click on each link and you’ll see the module is GONE in the article.
    I have an article with a right column which is empty. Where is the Who’s Online Module????? It’s supposed to be there.
    Is this not clear enough for you? If not let me know and perhaps we can do this via Messenger or by phone.
    I need this column in the articles, otherwise I’m not going to be able to use this template.
    Anonymous Moderator
    #334558
    Hi davidrabinov
    I now can see your issue.
    Please check two links:
    + http://www.panamasportsmagazine.com/index.php?option=com_content&view=category&layout=blog&id=13&Itemid=20&tp=1
    Here you can see the left and right position
    + http://www.panamasportsmagazine.com/index.php?option=com_content&view=article&id=322:chava-y-miss-chief-ganan-la-regata-de-cayucos-copa-tribunal-electoral-2010&catid=13:remo&Itemid=20&tp=1
    Here the left and right position are not exist
    I think it is from your configuration.
    Could you give me your live url, admin account via PM so that i could have a closer look on the issue?
    megaradio1 Friend
    #336494
    Hi!!! thanks for your support!
    I have a similar issue with a site using Teline III. The modules in the left and right position and showing up in the bottom as part of the article section. However, in any other page that is NOT the Home page they are correct.
    here’s the site:
    http://s238054144.onlinehome.us/870/
    I’m using the tabs module also in position col-mass1
    davidrabinov Friend
    #336495
    My issue was fixed, I don’t know what was done and if something was…I would like to know what. If you can post it here please.
    TY
    hellekim Friend
    #344299
    Does anyone know the solution for this?
    Dear hellekim!
    Sorry, Please kindly let me know which problems are happening on your site?
    Thanks a lot
    PS: pls give the link to your site
    hellekim Friend
    #344696
    I got similar issues on the right side and col-mass1, but I suppose megamenu is the clearest one. You can see it here:
    http://www.paitsio.com/
    http://www.paitsio.com/component/option,com_fjrelated/Itemid,102/id,126/layout,blog/view,fjrelated/
    But when you go to news pages – it disappears (and it IS set for all pages):
    http://www.paitsio.com/uutiset-kansainvaliset-sarjat/mestarien-liiga/ennakko-barcelona-arsenal/
    http://www.paitsio.com/uutiset-euroopan-liigat/la-liga/
    i’m sorry hellekim!
    can you pls give me the snapshot and draw same shapes on this. or try to explain the issue again
    hellekim Friend
    #346660
    I got the megamenu solved – the problem was that even thought the megamenu was for all pages, the login form wasn’t.
    But the issue on the right side is still there. For example if I select an advertisement spot for all pages, it is shown on all pages. If I take some pages off from the list, it won’t show anywhere.
    I use 3-columns-classic, but for frontpage I have set “1=default” for Page layout Overwrite.
    This is a huge problem for me as I need to be able to select module position!
    Somehow the template works strangely in the sense that it occasionaly turns on handheld or iphone mode in the web as well.
    Dear hellekim!
    May be you put wrong: as our demo: the Home menu has the ID 371: you the put the following text into the Page Layouts Overwrite parameter
    <blockquote>371=default</blockquote>
    Good luck
    hellekim Friend
    #347002
    I checked the main menu and the frontpage has “item id” 1.
    Dear hellekim!
    In your case, please kindly submit a ticket, we would like to check the issue in detail.
This topic contains 14 replies, has 5 voices, and was last updated by  Saguaros 14 years, 7 months ago.
