April 24, 2012 at 10:56 pm #176455
Hi everybody,
i’m working on a website based on a JA Events template and I’ve always had some help from your posts here since I started to work on it.Now it looks there is some problem with the right column I can’t solve. We use ADSManager in the website and when you click on some of the items of the menu on the right, the menu itself and all the stuff in the right column goes down, under the main content.
I’ve seen other posts here about this problem, but they couldn’t help.
I was wondering if somebody could take a look. The website is: http://www.audiovideo24.it.
The problem started with the “Diffusori acustici” item, but now it looks there is the same problem with “Cavi” and “Lettori CD”.Beside, first the problem is visible only on PC, now in my mac I can see it only for one of the items.
Can somebody help?
Let me know if you need some more informations.Thanks in advance.
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
April 25, 2012 at 5:00 am #450048Hi Discoste
I checking around your site and do not find “Diffusori acustici”, “Cavi” and “Lettori CD” as you said.
Can you send me link of them.
Addition: I think that may be you use third party SEF component and this system have duplicated link which make some issue to access items 🙂
<em>@dicoste 315862 wrote:</em><blockquote>Hi everybody,
Can somebody help?
Let me know if you need some more informations.Thanks in advance.</blockquote>
April 25, 2012 at 12:39 pm #450120Dear Hung,
thanks for your reply.
For the problem here there are some links of the pages that give problems:
“Cavi”
http://www.audiovideo24.it/annunci-usato/3-cavi.html
http://www.audiovideo24.it/annunci-usato/5-diffusori-acustici.html
“Lettori CD”
http://www.audiovideo24.it/annunci-usato/7-lettori-cd-meccaniche-cd.htmlYes we use a SEF component, but until some days ago there were no problems.
I thought the problem could be in the width of the column, but modifying it nothing changed.
I also checked if there is some <div> missing in the ads of AdsManager but I couldn’t find any.Any ideas?
Thank you.HeR0 FriendHeR0
- August 2011
April 26, 2012 at 2:44 am #450230Okie, i checked 3 link that you sent. Now, i think that module menu categories on right column is incorrect on SEF. Please clean cached and purge all urls for solve this issue. If the issue still persists, please send me FTP account and admin account. I shall have a look.
April 26, 2012 at 7:52 am #450284<em>@Hung Phung 316123 wrote:</em><blockquote>Okie, i checked 3 link that you sent. Now, i think that module menu categories on right column is incorrect on SEF. Please clean cached and purge all urls for solve this issue. If the issue still persists, please send me FTP account and admin account. I shall have a look.</blockquote>
With “clean cached” you mean I should clean the cache of Joomla in the administrator panel?
What you mean with “purge all urls”? For that menu I used external link type and I picked up the links from the “home” of ADSManager here: http://www.audiovideo24.it/it/annunci-usato.html. Infact in these links there is the same problem (for exemple with “Cavi”).
What I don’t get is why there is this problem only with some links and not with others…Thanks
HeR0 FriendHeR0
- August 2011
April 26, 2012 at 8:35 am #450291<blockquote>With “clean cached” you mean I should clean the cache of Joomla in the administrator panel? </blockquote>
=> yes<blockquote>What you mean with “purge all urls”? For that menu I used external link type and I picked up the links from the “home” of ADSManager here: http://www.audiovideo24.it/it/annunci-usato.html. Infact in these links there is the same problem (for exemple with “Cavi”).</blockquote>
=> If you use external link, please add language element into them. You can see different between http://www.audiovideo24.it/it/annunci-usato.html with http://www.audiovideo24.it/annunci-usato/3-cavi.html is “/it” which is element of language siteIf the issue still persists, please send me FTP account and admin account. I shall have a look.
1 user says Thank You to HeR0 for this useful post
April 26, 2012 at 3:08 pm #450335Dear Hung,
i cleaned the cache, but i didn’t solve.
For what concern the link, you made me remember that we have also Joomfish component on this site. Now I have published the module for the Language selection and I noticed that in the English side, the problem, for exemple with “Cavi” doesn’t show up, everything is normal to me. Can you tell if for you is the same?
This is strange…
By the way I tried to change the url as you told me, but, with the link of “Cavi”, for exemple, it doesn’t change anything.Any other idea? :-[
<blockquote>If the issue still persists, please send me FTP account and admin account. I shall have a look. </blockquote>
I’m just working on it, I’m not the owner. I ask and in the case I’ll send you a pm, thanks!April 27, 2012 at 2:01 pm #450533I found out the solution of the problem!:D
There was some conflict with the code of the description of the categories in AdsManager. I cleaned them from strange code and now everything’s fine!BTW thanks for your help and time.
This topic contains 9 replies, has 2 voices, and was last updated by HeR0 12 years, 8 months ago.
