  • hevzicuci Friend
    #160229
    I need to set the width of the right column to 300px for Telnie iii v2. I tried the CSS files but no luck.
    You acceess the template configuration and click to the Layouts Tab, then edit the Default Layout, => You find the following code:
    [PHP]
    <blocks name=”middle” colwidth=”20″ fixheight=”1″>
    [/PHP]
    You adjust value 20 by others number to change width of the right column.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 13 years, 9 months ago.
