  • jschroeder Friend
    #188970
    Hi i found a second issue I am using Joomla 2.5 plugin version 1.4.0 and newest mitius template. I am also using the newest version of rsformpro module. If I turn on AJAX validation the right hand column does not expand so you can see the required fields that you forgot to fill in. Instead the overflow goes behind the module below it. You can see what I am talking about here submit the contact us form without actually filling out any of the fields in the form:
    http://67.43.0.200/~gmenctrs/products-collections/our-collections.html
    How do i fix this? I need to use AJAX validation but the framework does not recognize that the column needs to expand.
    thanks,
    Josh
    Ninja Lead Moderator
    #499132
    You can fix the problem of rsformpron with this way
    Open templates/ja_mitius/js/script.js file
    find
    //fix for JA Tabs
    if(JAMHelper.ready) {
    $('.main-siderbar .ja-tabs-title, .main-siderbar .ja-accordion').on('click', function (argument) {
    clearTimeout(JAMHelper.sid);
    JAMHelper.sid = setTimeout(JAMHelper.resize, navigator.userAgent.match(/Mobile/i) ? 1300 : 1100);
    and change to
    //fix for JA Tabs
    $('form').on('submit', function (argument) {
    Let me know if it helps
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 11 years, 5 months ago.
