  • monimono Friend
    #179569
    hi
    i using t3 for more then two years and we love it.
    i have a strange problem when im using the right-mass-top position.
    the problem is when im using right-mass-top it create one more right column and not displaying above the right column and the main body become 50% of his orginal widh (see attached image).
    what should i do to make right-mass-top display above right column and not on the side of right column?
    thanks
    here is my code:
    <?xml version=”1.0″ encoding=”utf-8″?>
    <layout name=”desktop”>
    <!–Extra css load for this layout–>
    <stylesheets>
    </stylesheets>
    <blocks name=”top” style=”xhtml”>
    <block name=”ctera-top” type=”ctera-top”></block>
    <block name=”slidshow” type=”modules”>slidshow</block>
    <block name=”topsl” type=”spotlight” main-inner=”1″>top1,top2,top3,top4</block>
    <block name=”top-news” type=”spotlight” main-inner=”1″>top-news1,top-news2,top-news3,top-news4</block>
    <block name=”bradcrumbs-header” type=”modules”>breadcrumbs, page-header</block>
    </blocks>
    <blocks name=”middle” colwidth=”31″>
    <block name=”content-mass-top”>content-top</block>
    <block name=”right-mass-top”>right-top</block>
    <block name=”left1″>left</block>
    <block name=”right1″>right</block>
    </blocks>
    <blocks name=”bottom” style=”xhtml”>
    <block name=”botsl” type=”spotlight” main-inner=”1″>bottom1,bottom2,bottom3,bottom4</block>
    <block name=”bottom-logos” type=”modules”>bottom-logos</block>
    <block name=”footersl” type=”spotlight” special=”right” specialwidth=”40″>footer1,footer2,footer3,footer4,footer5,footer6</block>
    <block name=”bottom-socials” type=”modules”>bottom-socials</block>
    <block name=”ctera-bottom” type=”ctera-bottom” main-inner=”1″></block>
    </blocks>
    </layout>
    1. t3
    HeR0 Friend
    #462943
    Hi Monimono
    Please look at http://wiki.joomlart.com/wiki/JA_T3_Framework_2/Guides#Layout_Variations
    Hope that can help you !
    Regards,
This topic contains 2 replies, has 2 voices, and was last updated by  HeR0 12 years, 5 months ago.
