  • thewraith2 Friend
    #170042
    I am using “Freestyle FAQs Lite” version 1.5.6 (http://www.freestyle-joomla.com/products/freestyle-faq). After searching for a parameter my right modules are shoved down and are out of normal position (see attached screenshot). I’m assuming this is a Freestyle FAQ Lite issue but was wondering if anyone had run into this and had pointers on some code changes to resolve.
    Thanks in advance.
    1. faq-columnissue
    khoand Friend
    #421536
    Could you give me a link to your page has problem? I will check it.
    thewraith2 Friend
    #421537
    khoand Friend
    #421712
    Do you solve it? Because I see your website is normal.
    thewraith2 Friend
    #422186
    No, it’s still an issue. If you view the FAQ and do a search…THAT is when you see the problem.
    khoand Friend
    #422196
    I see it. Could you give username+password of your backend and ftp? I will check it.
This topic contains 6 replies, has 2 voices, and was last updated by  khoand 13 years, 1 month ago.
