  • turminator Friend
    #160730
    I detected that righ modules show wrong with this view:
    http://nudos.barcelonacreations.com/index.php?option=com_content&view=category&layout=blog&id=78&Itemid=473
    Is strange because in other looks good. What happening?
    Many thanks!
    #378797
    Dear turminator,
    The issue may is related to your article contents,Just try to disable your articles,one by one to find out the one casued the problem,if that still not help you can give me your admin account,the FTP Info via the ticket of IRR-178-20258 I will have further checking on the issue.
    aman204 Friend
    #378832
    As dathq suggested, Check in your articles assigned for mismatch of p, div tags or closing </div> tags if they tend to be missing (The article html code can be checked easily with editor turned off)
    turminator Friend
    #378942
    I solve it.
    Many thanks!
This topic contains 4 replies, has 3 voices, and was last updated by  turminator 13 years, 9 months ago.
