January 30, 2007 at 7:52 am #118548
using narrow screen, all modules published on the right, go to the left with IE6. With IE7 and Firefox all seems good. Also when I change to wide screen all settle well.
Any body knows the answer for this bug?
Thank you in advanced,
Strats
January 30, 2007 at 8:02 am #213882A solution I have found is to change the default width from 750 to something a bit wider:
I changed this:
.narrow #ja-wrapper {
width: 750px;to this:
width: 780px;Now it works OK. I don’t know if this was the propper solution, maybe an expert could advise
Thanks,
StratsKhanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
January 30, 2007 at 11:22 am #213893It may be ok in your case 🙂
February 1, 2007 at 12:45 am #213955I have the same problem.
I have found the code in template css .
I changed it but the menus still go to the bottom leftThis does not happen in Firefox or Netscape (agree with Strats) so it seems this template is not browser compatible
Please – can anyone help -Khanh just saying that it may be OK is not the answer
just migrated the site from joomlart MBT grey and this is very frustrating
February 4, 2007 at 8:01 am #214066Hi mrdhall,
Have you tried to modify the css as I described above? It solves the problem.February 4, 2007 at 7:57 pm #214082Hi Strats- Yes I did (plus altered it to 700 as well)
Sill drops the navigation to the bottom LHSSeems the Joomlart people are not interested in helping
Pays your money !!!!!!!!!
February 5, 2007 at 4:31 pm #214127See if you have any picture published at any module on the left. If yes, reduce the size of the picture. Obviously the template is not 100% tuned for IE6 but I believe there are solutions for each possible problem.
February 5, 2007 at 5:13 pm #214128Strats.
Nothing published in the left module position at all . Wanted to keep it all to the right . I thank you for your help but feel Khan and his team are not helping when they couldFebruary 5, 2007 at 5:41 pm #214130mrdhall, I just saw you said you altered it to 700. It has to be wider than 780!
width: 780px;February 6, 2007 at 4:19 pm #214166<em>@Strats 7549 wrote:</em><blockquote>mrdhall, I just saw you said you altered it to 700. It has to be wider than 780!
width: 780px;</blockquote>
Maybe you misunderstood me.
I changed it from 750 to 780 – no improvement
I tried it on 700px as well – no improvementits now back to 750px -its default size
This topic contains 10 replies, has 3 voices, and was last updated by mrdhall 17 years, 10 months ago.
