  • Danny Janssen Friend
    #176913
    I want an extra menu showned at the right side when somebody choised for ex. http://www.oelie.be/oelie/index.php/explore/websites/visitekaartje-pakket
    I tried everthing but the menu ‘websit’e isn’t visible . So a little help from my friends 😉
    TomC Moderator
    #452427
    Might you be able throw together a mock-up screenshot of how you’re wanting your page to display?
    #452441
    I have put the module in user 1, so it is visible. I want it on the same place as the demo page http://www.joomlart.com/demo/#joomla25-templates.joomlart.com/ja_puresite: the search,highlite and tab module
    1. voorbeeld
    aris Friend
    #452494
    you can use position-5 or position-7
    mvollero Friend
    #452675
    sometimes position 7 appears below the content if you are loading a category blog layout. Where should they be on this layout?
    1. Screen-Shot-2012-05-11-at-7.10.54-PM
    Stork11 Friend
    #452710
    <em>@mvollero 319230 wrote:</em><blockquote>sometimes position 7 appears below the content if you are loading a category blog layout. Where should they be on this layout?</blockquote>
    Hello mvollero,
    Depends on your template, position name for right position maybe different. It’s not always “position-7”. You can find all position by using “http://your-site.com/?tp=1”.
This topic contains 6 replies, has 5 voices, and was last updated by  Stork11 12 years, 7 months ago.
