Viewing 1 post (of 1 total)
  • GeoVi Friend
    #152754
    I’m not sure what I did to cause this but the modules in the right position have shifted to the left position.
    I tried disabling modules to see if that helped but no change. It appears with our without the right position layout, the homepage is not formatted properly at the footer section. All other pages are fine.
    I tested right position on other pages and modules work fine. The homepage is the issue.
    Your help is needed and appreciated. Thanks!
    I tried to attach an image but it gives me an error. grrrrrrrrrr – the site is here, thanks!
    Kind regards,
    Geovi
    ___________
    Through trial and error, I figured it out. Actually, I was experimenting to answer another problem a user has in eliminating the body on the frontpage. In my attempt to help him, I figured out my own problem. (Didn’t figure his out, though).
    After disabling all the articles on the frontpage, the right modules appeared. The problem was obviously the articles. I had copied and pasted in Wordpad. No problems before. Bennitos had taught me to use the Word feature in my editor to clear Word formatting. I did this and it solved my problem.
    Thanks Bennitos for being a great teacher!
This topic contains 1 reply, has 1 voice, and was last updated by  GeoVi 14 years, 5 months ago.
