lion_os Friend
lion_os
- February 2010
March 8, 2010 at 12:59 am #149285your template is very nice that i paid 70$ just to get it …unfortunately ..not much attention is been given to RTL support..
chick out the login button after changing to RTL direction..
look at breadcrumb….also the right column doesn’t shift to left …also the front page news..
i know you are busy with ja-voice and other plugins …
but please …give this template some time …and get it working nice with RTL support
thanks
lamvt Friendlamvt
- December 2006
- 52 times in 46 posts
March 8, 2010 at 10:57 am #335302What your RTL problem???
pls check Teline III RTL here if you like it
http://www.immigrace.com/lion_os Friendlion_os
- February 2010
March 8, 2010 at 6:38 pm #335374thanks for your help…however ..
I used the quickstart installation for telline iii …then i installed arabic ….it dosen’t work as you show on your site ..
i think you have done some css-customization …unfortunately i don’t know css
the joomlart have done RTL nice with Lime …so i just ask them to do it nice for telline iii and seleni ii please …
is that too much for 70$
thanks
- 2008 times in 1700 posts
March 10, 2010 at 3:40 am #335560Hi lion_os
We have updated RTL to teline iii. Please kindly check our demo site: http://templates.joomlart.com/ja_teline_iii/?direction=rtl
- February 2010
March 10, 2010 at 12:48 pm #335627hi
did you notice that the buttons for [ login twitter tool…etc ] don’t work..?!
try to navigate the demo site and see how the breadcrumb look..!
for an RTL site … the content should be on the right and the columns on the left ..!
for JA news frontpage module ..the headlines should be on the left and the leading artical on the right ..!
for the sections on the front page content the sectons names [ world…technology…entertainment…etc] should be on the right and the opposing buttons on the left..
look down the images in a given artical ,if it has more then one image …you will see [ of 1 3 ] instead of [ 1 of 3]..!
a perfect example for you to chick is JA Lime and :
or
choose فارسي
thanks
March 12, 2010 at 2:38 am #335881Hi lion_os
I am sorry for this mistake. I have reported this issue to our team again for checking. I will inform very soon.
March 13, 2010 at 6:10 pm #336115from where i can get the rtl ja jeline template please ?
March 15, 2010 at 3:53 am #336196Hi fat7i
Please go to this link: http://www.joomlart.com/forums/downloads.php?do=cat&id=143
You can download and install again
Hope it helps
- February 2010
March 16, 2010 at 12:25 am #336341they fixed most of the RTL problems
however the following issues are not fixed yet:
1- the (member) login button..twitter..
2- the breadcrumb ..”arrow” images
please let them fix quickly
I also have a quistion regarding the breadcrumb:
how do i change the text ” you are here: ” to some arabic text
thanks alot
lamvt Friendlamvt
- December 2006
March 16, 2010 at 4:05 am #336366I also have a quistion regarding the breadcrumb:
thanks alot
pls Open your template files with any editor software like Dreamware..
Search with key: you are here
and translate itlion_os Friendlion_os
- February 2010
March 22, 2010 at 2:46 am #337127<em>@lion_os 169596 wrote:</em><blockquote>they fixed most of the RTL problems
thanks alot</blockquote>
hi
any news or update regarding the aforementioned problem ?i was told that it will be fixed very soon
thanks
Aratype FriendAratype
- August 2007
- 98 times in 6 posts
April 3, 2010 at 8:36 am #338957I installed Telline III 1.4.1 and found rtl stufs in css… However, I do not know how to drop ltr and have only rtl configuration…
By the way… changing “You are here” to the Arabic corresponding sentence needs installing Arabic Language in Joomla…
This topic contains 12 replies, has 5 voices, and was last updated by Aratype 14 years, 8 months ago.
