December 4, 2008 at 2:12 am #135923
After the installation of Sanidine to the last step before deleting the installation folder, I get these 2 messages
1. Duplicate entry ’10’ for key 1 SQL=INSERT INTO jos_core_acl_aro VALUES (10,’users’,’62’,0,’Administrator’,0)
2. Warning: file_put_contents(D:Hosting3528589htmlconfiguration.php) [function.file-put-contents]: failed to open stream: Permission denied in D:Hosting3528589htmlinstallationinstallermodelsmodel.php on line 850
can someone help please,
thanks in advance,
Sherlock FriendSherlock
- 2478 times in 2162 posts
December 5, 2008 at 9:39 am #281394Hi changedaily !
Please try to drop all table of database what you are use for install before install sadinite quickstart .December 9, 2008 at 7:25 am #281891Thanks for your help, i figure a way around it. This might sounds easy to you but is there a way to change the width of the template Sanidine II? Thanks again
December 9, 2008 at 7:38 am #281895Hi changedaily !
To change width of sanidine ii , you do it following way below :
Open template.css file in templates/ja_sanidine_light/css folder, find following code section at about line 550 :
#ja-wrapper {
background:transparent url(../images/wrapper-bg.png) repeat-y scroll center center;
clear:both;
margin:0 auto;
width:950px; // edit this attribute as you wish
1 user says Thank You to Sherlock for this useful post
December 24, 2008 at 5:59 am #283914I have another problem uploading plugins and modules, by any chance can you tell me what am I doing wrong here. So I go to Extension>Install/Uninstall hit the browse button in the Upload Package File field and then hit upload files / Install and this is what i get
* JFolder::create: Could not create directory
* Warning! Failed to move file.December 28, 2008 at 11:57 pm #284192Hi,
when installing the template with sample data I get the same error message you mention in point 1 (duplicate entry …). I only get this when installing with sample data and in that case I get a blank page on the front end. I dont have this issue when installing without sample data, but then of course I miss out on most of the goodies that come with the template.
Any ideas … ?
Patrick
cjmicro Friendcjmicro
- June 2008
- 81 times in 10 posts
December 29, 2008 at 11:49 am #284234* JFolder::create: Could not create directory
* Warning! Failed to move file.A few things:
This could be permissions problem on the folder you are trying to install to.
To check folder permissions you can go to help/system info, and then the directory permissions to be sure the correct folders are writeable.Also check that you have the livesite in your config correct.
The other thing is to be sure you have enough room on your server to install and add things. (make sure you can ftp files to the folder you are trying to install to, to be sure it’s not a server issue)
If you do a search on this forum and on joomla forum for this error you will find a lot of ideas and info if these don’t help.
Cheryl
December 30, 2008 at 3:27 am #284284Hi
First, you must CHMOD media folder to 777.
If you want to install module, you must CHMOD modules folder to 777
If you want to install component, you must CHMOD components and administrator/components folder to 777Then you can install as you want.(after install please CHMOD those folder back again as begin or 755)
Or you can unzip that extension, then upload to media folder, use install from directory
Hope this help.
December 30, 2008 at 8:29 am #284298Hi guys,
there does not seem to be an answer yet for the first point raised by the original poster:
I get this too when installing the sample data, and the front end is blank afterwards.
What can be the cause ?
Cheers,
Patrick
This topic contains 9 replies, has 4 voices, and was last updated by pdemaers 15 years, 9 months ago.
