  • phpmaruja Friend
    #117680
    I’m getting troubles with virtuemart :-[
    Blocks on left & rigth come below when the bougth products list is displayed :confused:
    How can I solve this problem?
    I love this template :-*
    Sorry, I’m spanish …. Any one here speaking spanish ??
    thanks, Wait answer , please
    tonydel Friend
    #212025
    Anyone can answer this?
    Khanh Le Moderator
    #212031
    I guess that this problem occurs in IE6. You should check your content if there’s something wider than its container?
    twinpopsies Friend
    #212122
    Please help. Left and right columns go down when I click “add to shopping cart”.
    Here’s my link: http://www.bandwagondelivery.com
    Please click the “add to cart” link from the feature product module on the right to see what I mean. I need to fix this asap.
    Thanks.
    twinpopsies Friend
    #212200
    Im using firefox 2.0 and safary. The left and right columns go down when I click “add to cart” in virtue mart. How do I fix this?
    I beg you. Please help.
    Khanh Le Moderator
    #212209
    i twinpopsies,
    The virtuemart Show cart page generates an unwanted code at the end of the mainbody make the layout broken. This is the generated code:
    </div>
    <br style="clear:both;" /><br/>
    You could fix this problem by your self or contact the author of the component.
    twinpopsies Friend
    #212245
    <em>@khanh 4682 wrote:</em><blockquote>i twinpopsies,
    </div>
    You could fix this problem by your self or contact the author of the component.</blockquote>
    Hi sir,
    I’m not a php developer so I am wondering how I can fix this myself. Is it safe to take out thos codes you mentioned above?
    Khanh Le Moderator
    #212272
    Hi twinpopsites,
    In this case, you should contact with author of the component to request a help or get some freelancers help you.
This topic contains 8 replies, has 4 voices, and was last updated by  Khanh Le 18 years ago.
