September 23, 2015 at 10:29 am #691826
I’m having trouble with laptop and Ipad display when I use thememagic to change the colour. The site will works perfectly in the original template colour options but as soon as I change the primary colour or any of the other settings it stretches the screen too much. I found a similar forum post http://www.joomlart.com/forums/topic/laptop-layout-too-wide/ and applied the custom code but the sites layout is now messy.
Hope the above makes sense 😉 and I hope you can help!
Michelle
Saguaros ModeratorSaguaros
September 24, 2015 at 6:39 am #692161Hi Michelle,
When I view your site in laptop or iPad, it still displays fine, could you send me the screenshot highlightin the problem here?
September 24, 2015 at 6:39 am #749561Hi Michelle,
September 24, 2015 at 10:50 am #692189<em>@Saguaros 493896 wrote:</em><blockquote>Hi Michelle,
When I view your site in laptop or iPad, it still displays fine, could you send me the screenshot highlightin the problem here?</blockquote>
Hopefully you can see what I mean – boxes won’t line up properly when i’ve tested on laptop and ipad and I also really wanted 1080 to be full screen as it is in demo site – it does this when around the site when i’m using the boxes feature.
Also when I’m using these boxes is there a simple way to make the whole box clickable instead of just the title and the read more?
Thanks,
MichelleSeptember 24, 2015 at 10:50 am #749589<em>@Saguaros 493896 wrote:</em><blockquote>Hi Michelle,
Thanks,
MichelleSaguaros ModeratorSaguaros
September 25, 2015 at 2:38 am #692401Hi Michelle,
The text in the 4th item is so long so that it causes that issue. You can try this way:
– Open the css file: root/templates/ja_medicare (your default template)/css/custom.css
– Add this rule:
.category-module.five-columns .category-module-item {
min-height: 290px;
September 25, 2015 at 2:38 am #749660Hi Michelle,
– Add this rule:
min-height: 290px;
September 25, 2015 at 10:05 am #692465Thanks that seemed to work 🙂
Did you know to make the whole box clickable?
September 25, 2015 at 10:05 am #749702Thanks that seemed to work 🙂
This topic contains 11 replies, has 2 voices, and was last updated by Saguaros 9 years, 1 month ago.
