March 6, 2017 at 9:15 am #1015602
the homepage for some reason doesn’t scroll smootly.
It seems to be something in the home module (in the other pages the problem do not show).How can I remove this effect?
Thank you-Defende
March 6, 2017 at 9:16 am #1015603The site is aigem.it
Saguaros ModeratorSaguaros
March 7, 2017 at 9:01 am #1015943Hi Defende,
Could you clarify the issue in more details so we can check? as I can see the home page of your site still scroll fine.
March 7, 2017 at 9:27 am #1015957Hi,
it’s difficult to describe the issue.
The site is http://www.aigem.it/If you see the homepage and try to scroll you will se the problem.
The scrolling is not smooth.How can I resolve this?
Thank youSaguaros ModeratorSaguaros
March 8, 2017 at 9:47 am #1016274Hi,
You can send screenshots or record a video to illustrate the issue as it’s hard to suggest without seeing issue.
March 8, 2017 at 11:01 am #1016295Saguaros ModeratorSaguaros
March 9, 2017 at 3:32 am #1016505With all due of respect, but I can’t see the issue here, so may I know how you want it should be here?
March 10, 2017 at 1:05 pm #1017138There is a jump during the scroll of the page.
March 13, 2017 at 3:33 am #1017573You can try this way:
- Go to file: ROOT/templates/uber (your default template)/css/custom.css (create this file if it doesn’t exist)
- Add this css rule:
.uber-header.header-7.light-color { position: fixed; } .acm-slideshow { padding-top: 157px; }
This topic contains 8 replies, has 2 voices, and was last updated by Saguaros 7 years, 8 months ago.
