September 8, 2009 at 6:21 am #144007
When I turn Search Engine Friendly on after my installation every page other then my homepage loses the template layout. Ive tried renaming the htaccess.txt to .htaccess however that doesn’t solve the problem. Please go to http://www.cib-guild.com to see what I mean.
prakash Friendprakash
- October 2008
- 146 times in 115 posts
September 8, 2009 at 6:30 am #316743Yes, it will because with URL rewriting your css files are being written as
http://www.cib-guild.com/index.php/templates/css/<yourcss>.css
actually it should be
http://www.cib-guild.com/templates/css/<yourcss>.cssi think you are also using shsef ….so what is happening is that other articles are… like
http://www.cib-guild.com/index.php/n…de-of-darknesswhen it should be
http://www.cib-guild.com/news/47-sev…de-of-darkness
bennitos Friendbennitos
- May 2008
- 474 times in 407 posts
September 8, 2009 at 8:37 am #316769what mostly causes this is the $live_site variable in the configuration.php file.
Open your configuration.php file and look for the “var $live_site =”
In your situation it should be:
var $live_site = ‘http://www.cib-guild.com/’;
September 8, 2009 at 4:32 pm #316827<em>@prbalge 143792 wrote:</em><blockquote>Yes, it will because with URL rewriting your css files are being written as
http://www.cib-guild.com/news/47-sev…de-of-darkness</blockquote>
How do I fix this?
- October 2008
September 8, 2009 at 5:33 pm #316830like bennitos has suggested you can see if the value is in your live site in configuration.php …also see if you have used the complete url in the shsef settings…that might also be causing the problem.
September 8, 2009 at 6:04 pm #316833I fixed most of the problems with the confguration.php howver im not sure what this “shsef settings” you are refering to is. If you could explain how to do this?
- May 2008
September 8, 2009 at 9:24 pm #316845Its a seperate module you can download to use Search friendy url’s you can use it if you dont want to use the build in fuctions.
I would personally recommend 404sef
This topic contains 7 replies, has 3 voices, and was last updated by bennitos 15 years ago.
