  • mstoss Friend
    #156298
    I need to use pop-up windows to display interactive content. Using normal HTML this works just fine and it is working fine even with Joomla and SEF turned off. But when I switch to SEF turned on, the path for the popup window is becoming wrong.
    When I use this code in the article:
    <a href="#" onclick="javascript:window.open('images/stories/panoramatour/messe/tw_iyc_v1.html','_blank','status=yes,top=0,left=0,width=660, height=526');">link</a>
    it is correctly opening a new window with this path:
    http://pavomedia.de/panoramen/images/stories/panoramatour/messe/tw_iyc_v1.html
    When I use the same code and turn SEF on, I receive this path (and Page-not-found-error) instead:
    http://pavomedia.de/panoramen/index.php/galerie-beispiele-360-grad-panorama/images/stories/panoramatour/messe/tw_iyc_v1.html
    Is there any solution for this?
    Thanks in advance,
    Michael
    korb Friend
    #362573
    This is not a template related issue. Some SEF engines do a bad job with those kind of links you have and I think extensions like sh404SEF already fixed that.
    For core SEF please try to find a solution in the Joomla.org forums.
    Regards,
    Danny
    VisiGod Friend
    #362576
    <em>@korb 203179 wrote:</em><blockquote>This is not a template related issue. Some SEF engines do a bad job with those kind of links you have and I think extensions like sh404SEF already fixed that.
    Regards,
    Danny</blockquote>
    Try using SEF with mod_rewrite.
This topic contains 3 replies, has 3 voices, and was last updated by  VisiGod 14 years, 1 month ago.
