  • dlocc Friend
    #132872
    Problem: When Search Engine Friendly USLs are turned on the header for sub-menu items do not appear. With it turned off they work fine. example http://www.policydrafts.com No submenu items appear. How can this issue be resolved?
    dlocc Friend
    #268796
    I guess the simple fix is this:
    Create a new Module for Custom HTML and then insert your header image. (in this case I will use header2.jpg) templates/ja_mageia/images/header/default/header2.jpg
    Give the module a class suffix name ( for this example I will use the suffix name “actions”
    Open templates_css.css
    Add the following lines:
    /* Custom Headers for Search Engine Friendly URLs */
    div.moduletableactions {
    padding-left: 219px;
    You will notice that the header image is now properly placed but the gray bar at the bottom is now covered up. Either add this in with photoshop and call a new photo or ?… I haven’t figured out another method quiet yet. Will post if I do soon. Just started working on this problem a bit ago again. Thanks
This topic contains 2 replies, has 1 voice, and was last updated by  dlocc 16 years, 4 months ago.
