February 12, 2011 at 9:38 pm #160098
I use the latest Teline… when turning on Joomla’s SEF and click on a menu item it seems the css is completely removed (see attached).
I also tried to use SEF404 instead of the native Joomla one and removed the htaccess to use the without htaccess setting, but to no effect
Any idea?
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
February 12, 2011 at 9:57 pm #376428Please provide a link to your site. Or PM me an admin logon so I can take a look directly. If you do PM me please incluse a link to your site and a link to this thread.
- February 2014
February 16, 2011 at 10:37 pm #377029Thanks for your PM.
I have checked your site and your problem is not template related. I have checked your site with the default template as ja purity, beez and as rhuk_milkyway and all exhibit the same problem in that you loose all css when you navigate away from the homepage. There also seems to be a lot of security on your site as it was constantly giving me “prohibited” and “flood control” errors. You will need to investigat other extensions that you have installed which might be causing you these problems. It may even be server related. Sorry I cannot help further.
mrfast Friendmrfast
- November 2010
- 4 times in 1 posts
February 17, 2011 at 2:41 am #377051I think the first of all you should remove all extension SEF404 and relevant, after that clear all cache, restart browser and try again.
Best regards.February 19, 2011 at 4:14 pm #377477I am having the same problem on my site http://www.africaglobalvillage.com I am hosting other websites on the same server and I have been able to turn ON the search Friendly URLS so I do not believe it is the server. it has to be sometjhing with JA_Teline_III_v2 I Installed using the express installation.
Everything is running OK but I need to do this to get more traffic
- February 2014
February 19, 2011 at 5:28 pm #377482Your site is currently working for me with what appears to be sef url’s
February 19, 2011 at 5:33 pm #377483I found the solution just after I posted and this might work for Waterflake. If joomla installation is not in the root folder you have to go edit config.php and add in the Parameter $live_site the fullpath like “http://wwww.yoursite/yourfolder
once I did that I was able to change the global settings to yes and that is what you see
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 4 voices, and was last updated by emandowa 13 years, 10 months ago.
Search Engine Friendly URLs – click on menu destoys template
