  • kazu Friend
    #148214
    If I turn on “Search Engine Friendly URLs” in “Global Configuration”, only “Home” shows up, but all links are broken. I get “404 Not Found” errors if I click on any of the links from “Home”. I have selected “Yes” for “Use Apache mod_rewrite” and “No” for “Add suffix to URLs”. If I turn off “Search Engine Friendly URLs”, then everything works without problems. Also, I have renamed htaccess.txt to .htaccess, so that should not be the problem.
    These is the info about the server/DB I use:
    Database Version: 5.0.77
    Database Collation: utf8_general_ci
    PHP Version: 5.1.6
    Web Server: Apache/2.2.3 (CentOS)
    Web Server to PHP interface: apache2handler
    Joomla! Version: Joomla! 1.5.15 Stable [ Wojmamni Ama Mamni ] 05-November-2009 04:00 GMT
    How can I fix this problem? Thanks!
    lamvt Friend
    #330933
    ask you hostitng supporter about mod_rewrite
    Or send your live site, allow Us to check it for you.
    kazu Friend
    #331001
    Thank you for your reply: I checked and mod_rewrite is an installed module on the server. What can be the problem?
    lamvt Friend
    #331181
    <em>@lamvt 162680 wrote:</em><blockquote>ask you hostitng supporter about mod_rewrite
    Or send your live site, allow Us to check it for you.</blockquote>
This topic contains 4 replies, has 2 voices, and was last updated by  lamvt 14 years, 9 months ago.
