  • ihandler Friend
    #170892
    Hi, I applied the JA Bistro templete to the site, but seach module does not work.
    I did not touched anything about search related module.
    Can you help me to solve the problem?
    TomC Moderator
    #425599
    Might I inquire as to the method you used to upload/install your template?
    ihandler Friend
    #425604
    Hi, I installed the template using quickstart.
    Thank you for the quick response.
    TomC Moderator
    #425606
    Ok . . . at first glance, it does not appear that you have updated any of your extensions/elements within the Extension Manager.
    My recommendation is for you to first back-up your current site configurations using Akeeba Backup, and then update all of your various components/extensions and Joomla via the Extension Manager (Components/Extension Manager)
    See if doing this has any effect on your search function – let me know.
    If you are uncertain as to how to use the Extension Manager, [URL=http://www.joomlart.com/forums/topic/how-to-use-ja-extension-manager/
    ihandler Friend
    #425622
    update all the extensions as you directed.
    But the search result does not show. Thanks.
    ihandler Friend
    #425624
    Just in case, I installed the templete on my local machine.
    and searched “aaa” and found that the redirected urls are differnet.
    This url form the web page.
    http://www.sumiscakery.com/jab/index.php/component/search/?searchword=aaa&searchphrase=all&Itemid=435
    This url from local machine.
    http://localhost/btest/index.php/using-joomla/extensions/components/search-component/search?searchword=aaa&searchphrase=all
This topic contains 6 replies, has 2 voices, and was last updated by  ihandler 12 years, 11 months ago.
