  • jamenagemonjardin Friend
    #165415
    Hello all,
    I have a problem with the search module, using the mesolite ii template, like you can see here :
    http://www.jmj-test.com/
    I use css the tip written here ;
    http://www.joomlart.com/forums/topic/the-search-button-is-blacked-out-and-the-search-button-appears-on-the-left/
    But it’s not really well for the moment. I would like to see this :
    http://oakfloors.sway-search.co.uk/index.php
    Thank you for your help 🙂
    Olivier
    khoand Friend
    #397224
    You login backend Extensions > Module Manager > Search.Set Show Title is No, Search button is No, Box Width is 20.
    #397226
    Thank you…I did it, and when i do a research, i have
    Fatal error: Cannot redeclare pg_keydensesort() (previously declared in /homez.356/jmjtest/www/plugins/search/virtuemart.search.php:212) in /homez.356/jmjtest/www/plugins/search/vmxsearch.plugin.php on line 214
    Have you got an idea?
    And just to know, I have to use the search module, and not the virtuemart search module…Will it work to find a product?
    I wait your answer 🙂
    #397229
    Ok, i understand…You use the default search module. It works, but we can’t make a real product search.
    In order to not get this error, just publish one virtuemart search plugin (we have two).
    Is it possible to use the virtuemart search module in this position, please?
    Olivier
    khoand Friend
    #397243
    Yes, it is.
    – You set position of vm_search module is search
    – You replace this code from modulesmod_virtuemart_searchmod_virtuemart_search.php
    <p><label for="keyword"><?php echo $VM_LANG->_('PHPSHOP_SEARCH_LBL') ?></label></p>
    <p>
    <input name="keyword" type="text" size="12" title="<?php echo $VM_LANG->_('PHPSHOP_SEARCH_TITLE') ?>" class="inputbox" id="keyword" />
    <input class="button" type="submit" name="Search" value="<?php echo $VM_LANG->_('PHPSHOP_SEARCH_TITLE') ?>" />
    </p>
    with
    #397248
    Waou….You’re really really strong….
    Eventually, maybe you know how to enlarge the text-box to 20px? Where is the css for this module…?
    And, as I see you’re on the top, maybe you could help me for a 1456th problem 🙂
    If you go here :
    http://www.jmj-test.com/index.php?page=shop.browse&category_id=10&option=com_virtuemart&Itemid=1
    You can see every link toward a product or a category ends with
    The “1” at the end doesn’t change, and I don’t understand why…
    i.e. :
    http://www.jmj-test.com/index.php?page=shop.product_details&flypage=vmj_ritz.tpl&product_id=225&category_id=10&option=com_virtuemart&Itemid=1
    http://www.jmj-test.com/index.php?page=shop.product_details&flypage=vmj_ritz.tpl&product_id=384&category_id=10&option=com_virtuemart&Itemid=1
    http://www.jmj-test.com/index.php?page=shop.browse&category_id=23&option=com_virtuemart&Itemid=1
    etc…I can create a new thread if you prefer…
    Thank you very much again for all your help, php master 🙂
    Olivier
    khoand Friend
    #397251
    You replace
    with
    <input name="keyword" type="text" size="20" title="<?php echo $VM_LANG->_('PHPSHOP_SEARCH_TITLE') ?>" class="inputbox" id="keyword" />
    #397252
    Super, it’s working 🙂
    You’re great
    Concerning my url problem, you got an idea…?
    Thank you again 🙂
    khoand Friend
    #397417
    ItemId is menu_id. When a link contains “ItemId=3”, it means menu has id is 3 is actived.
This topic contains 9 replies, has 2 voices, and was last updated by  khoand 13 years, 6 months ago.
