  • msilac Friend
    #186796
    I have a strange problem with search module. When you type the word to search for and click search in the result it appears incorrectly part of the data in the right corner of page. See screenshot
    http://www.mojaakcija.com/TESTING/cepin
    1. cepin_screenshot
    msilac Friend
    #490118
    Any help please?
    Hi msilac,
    I cannot access your site, pls update link again.
    msilac Friend
    #490170
    Link is ok… but something is wrong with hosting loading is so slow… check now…
    msilac Friend
    #490322
    Can you check please?
    Thank you
    msilac Friend
    #490634
    Saguaros? Are you here?
    I tried but it directs me to a 403 page : http://www.mojaakcija.com/TESTING/cepin/
    <blockquote>
    Forbidden
    You don’t have permission to access /TESTING/cepin/ on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    </blockquote>
    msilac Friend
    #490816
    In the meantime 🙂 http://www.cepin.hr… well, time passing by
    Did you make any custom on the search form? since I see there is an additional <span> tag added to the number of search results:
    <span class=”badge badge-info”>47</span>
    In demo site, it looks like: <strong>Total: 47 results found.</strong>
    msilac Friend
    #491124
    NO, I didnt do anything… How to change that?
    You can add css rule to fix this issue:
    – Open file: /templates/ja_template_name/css/template.css
    – Add this rule:
    .badge.badge-info {
    background: none;
    position: relative;
    Then clean all cache.
    msilac Friend
    #493608
    That helps, thank you!
This topic contains 12 replies, has 2 voices, and was last updated by  msilac 11 years, 7 months ago.
