  • aram Friend
    #126121
    Hi all !
    I have notic that the teline temp has problem when you enabling the teline 1.5 mod_rewrite and sef . I have installed a clean jommla 1.5 and getting no problems , the teline mod_rewrite and se working goon for joomla 1.4 ,
    Is there any one who know how i can fix it ?
    Kind regards
    Aram
    Hung Dinh Friend
    #240927
    Are you sure that you have installed everything correctly?
    JA Teline is working fine with SEO enable at the 1.5 demo
    Please check if your download quickstart is the newest one? the QS I used at the demo is detailed in the attached image1031
    1. teline_qs
    aram Friend
    #240971
    Hi Again!
    Yes i have dl the newest JA teline for joomla 1.5 . And to be sure i done it again now to test it . Am getting the same problem when I enable sef , pages can not be found and getting 400 error.
    I have other templates , with them I don’t getting any problem…
    regards
    Josef
This topic contains 3 replies, has 2 voices, and was last updated by  aram 16 years, 9 months ago.
