  • hendersonline Friend
    #131459
    I upgraded my site through cPanel Fantastico from 1.5.2 to 1.5.4. Upgrade rewrote config.php back to default, so I switched back on Joomla SEF which worked fine under 1.5.2. This stripped all CSS and images out of the site, so it became just text and links. Uninstalling Joomla SEF did not return it back (not a cache problem) so I had to re-install old site.
    Any help gratefully received. I have other templates – Joomlart and others – happy under 1.5.4.
    What is problem here?
    Many thanks
    #262796
    Hi hendersonline !
    Please send url of your site.
    #262932
    Hi Hainn
    Many thanks for the quich reply.
    The site is http://www.caremicro.co.uk.
    I hope you can advise.
    Kind regards
    hendersonline
    #262933
    Hi Hainn
    Kind regards
    hendersonline
    #262966
    Hi hendersonline !
    I have looked into your site, but can’t find the problem , all link runs well . Have you fixed the problem ?
    #263110
    Hi Hainn
    Sorry, I may not have explained it well. The site is running OK now because I had to re-install the backup back to 1.5.2. When I went to 1.5.4 it just fell apart as described in my first post.
    Any thoughts?
    Thank you again
    hendersonline
    #263149
    Hi hendersonline !
    Please download JA News in teline ii version 1.3 and update it on your site.
This topic contains 7 replies, has 2 voices, and was last updated by  Sherlock 16 years, 4 months ago.
