  • gduran144 Friend
    #174328
    Whenever a SEF extension is installed and turned on, every page except for the homepage results in a 404 error. I have tried installing different SEF extensions but to no avail. I have also tried using SEF on different templates and it has worked fine. JA Kranos just doesn’t seem to want to be SEF’ed.
    Any suggestions?
    Manos Moderator
    #440202
    Did you rename the htaccess.txt file to .htaccess first ? SEF is working as on any other Joomla installation so it should work on your installation also unless there is something missing from your server configuration.
    gduran144 Friend
    #440240
    That solved the issue. Thanks a lot.
    Manos Moderator
    #440325
    You are most welcome, i am glad that this solved your issue! (Marking the problem solved)
This topic contains 4 replies, has 2 voices, and was last updated by  Manos 12 years, 10 months ago.
