  • ismailbabelli Friend
    #131746
    I am facing the same problem
    I installed teline 1 without any problems. I made some changes on CCS files only. I tested the links and I found them working properly. BUT after I made sigle change on one category name every thing went wrong>:( No single link is working any more and forwarding me to wrong blank page.
    My website link is http://www.forexsafari.com
    Any help please
    #263701
    Hi ismailbabelli !
    your problem is SEO error, I have checked your site , all link is wrong , now. Please explain detailt , how do you change your site .
    #263704
    <em>@hainn84 71397 wrote:</em><blockquote>Hi ismailbabelli !
    your problem is SEO error, I have checked your site , all link is wrong , now. Please explain detailt , how do you change your site .</blockquote>
    ok
    I just made changes on ccs files only. I did nothing else at all. When I comleted ccs changes I checked links (because this problem has happened before) every thing worked ok.
    Then I just changed on catigory wich is (asia-pacific) and I left alias blank ooops… all the links got crazy and started not to work. I returened the name back to asia-pacific without benifit.
    Well thats what happened only:confused:
    #263713
    I just went back to SEO Settings on and ticked NO on (Search Engine Friendly URLs) then links started to work again.
    I need my site to be Search Engine Friendly URLs. How can I solve this problem.
    #263715
    Ok ismailbabelli !
    Please send admin acc of your site via pm , i will check it for you.
    #263730
    Hi ismailbabelli!
    Please check . it is ok now. I fixed it by way :
    – Reconfig joomla seo
    – remove alias for menu .
    #263731
    oh
    Thank you very much for your help
    jmccann Friend
    #264168
    I have the same problems bur removing alias doesn’t work. I need SE Friendly URLS to work but if I set SE Friendly URLS to on, I lose all CSS styling and formatting.
    mjedick Friend
    #264173
    <em>@hainn84 71434 wrote:</em><blockquote>Hi ismailbabelli!
    – remove alias for menu .</blockquote>
    I have been having the same problem. I Reconfigured the Joomla SEQ setting like you showed, but how do I remove alias for menu?
    #264276
    Hi mjedick !
    To remove alias for menu you go to admin >> menu >> select main menu –> go to each menu item and remove alias below menu title .
    mjedick Friend
    #264342
    Thank you so very much. 🙂 I was able to make these changes before the site http://www.atlanticcityone.com grew to be so large that it would be a larger undertaking. You guys are awsome! Joomlart and hainn84 Rock!
This topic contains 11 replies, has 4 voices, and was last updated by  mjedick 16 years, 5 months ago.
